i have a wd my passport se 1tb usb 3.0 hdd.i ran hdd tune and it detected 98%bad sectors.i ran hdd regenerator but it run extremely slow l,about 100mb in 1 hr.Also it frequently says that connection to the hard drive has been lost.what should i do?please help.
Replace it!!! So many bad sectors and the slow regenerator process are things to consider!!
You can check if you’re still under warranty by clicking on this link. Try to take out the data while you can.
