Require some help…bit of a technophob here!!! I’ve had a WD HD TV LIVE media player now for a year, when i switch it on now the on/off light continually flashes and won’t recognize the hard disk and can’t get a signal on my tv…what’s wrong and can i fix it???
You can try doing a hard reset on the unit.
on the secondary USB connector, you will see a very small hole, please press and hold that for 14 seconds and it will do a hard reset.
This might help.
I’m so sorry for you being past the 30 day return period.
If the flashing is Three-Long/Three-Short/Three Long pattern, that means the hardware has failed diagnostics and won’t boot.
