Scenario : 2 x WD live streaming players – DLNA – must see the other as a media share Mediaplayer 1 is in living room – has 2 usb drives connected to it - connected to WD N900 router by Cable Mediaplayer 2 in bedroom access the router wirelessly . Cannot detect the other WD live in living room through media share or network share and see’s what data is on it and u stream it from the one to the other It works with an Apple TV2 accessing the WD live and plays the media content on the usb drive . I know I did this already at home ! Just not picking up the other WD live in media share when using 2 x WD live streamers … Surely they should be able to stream between them I am missing something ! Anyone at WD Tech that can help?
You have to change the “Device Name” for one of them.
Check page #30 of the user’s manual.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705062.pdf
WD’s are DNLA renders
not DNLA servers
but as already stated, you can make sure the device names are unique and then share between them using smb (windows shares)
