I bought a WD Live Hub Media Centre about 1.5 years ago. It is working fine but the remote controller that comes with the Live Hub Media Centre is made of inferior soft plastic that has melted & turned sticky to hand touch. I can no longer use this remote controller unless I wrapped it in a plastic bag or paper so that the melting plastic does not stick to my fingers.
I am generally disappointed that WD had used inferior soft plastic to make the remote controller; the device itself is otherwise working fine.
Last year we had one remote go sticky overnight and recently another! They were not in hot areas or any place that could get sticky and nothing else around them was sticky.
Unrelated to WD, I had a mouse about 3 years ago that experienced the same problem. I used it one night, next day, sticky!
I’ve had mine since they came out.
This only happened to the larger remotes, the small ones are still fine.
