how do i hook up to dsl modem via ethernet cable
not setting automatically and how do i find setting to enter manually
the att modem is 2wire
i also have live plus in second room too
The physical connection should be to any one of the Ethernet jacks (usually four of them). The automatic settings SHOULD work. If not, try unplugging and resetting both devices. I’m not sure about the manual settings that’s a pain. Make sure you’re selecting WIRED for ethernet. Wireless is for a USB wireless adapter. If you ever get a USB Wi-Fi adapter, get the “N” version and choose from the LIST of supported hardware for the WDTVLIVEHUB. Can find one on sale for about $15.
