Wd live box and wlan?
I am thinking to connect the box over a wlan stick with the network.
https://wdc.custhelp.com/app/answers/detail/a_id/3805/~/list-of-compatible-devices-for-the-wd-tv-live-hd-media-player-and-wd-tv-live
I think the “TP-Link TL-WN821N” from the list should be ok, but how can I set up wlan settings at the wd box?
As far as I can see, there are not options at the menu.
Regards,
Spyke32
Make sure it is Ver 2.2. If it is not the same version it might be incompatible.
Also review the steps on page #25 of the users manual.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705043.pdf
hm, the current Version from the tp homepage is 4.0
http://www.tp-link.com/lk/products/details/?model=TL-WN821N
and the online traders does not specify the version. I think the same version is quite impossible.
I searched for a stick which would also be compatible with a raspberry pi, this one was also on the list.
But this seems to be difficult, by many sticks, there is no version given.
