WD HUB, Internal Drive not recognizing after re-partitioning in PC
I removed the internal 1TB drive which had 3 partitions. Recreated 2 PARTITIONS “WDTVPri” :-963MB “WDTVLiveHub”:-Remaining 930GB…Both drives are ntfs. I copied all my data to the second partition. After inserting it back, it doesn’t recognize my internal HDD anymore… Is there any specific way that the partitions need to be or how can I make the HUB recognize the partition…Is it possible to recover the drive Partitions To ITS DEFAULT STATE…
I don’t think you can…
Just delete all the partitions and put it into the hub partitionless.
