Hi guys I have a WD TV HD Media Player (Gen 2) WDBABF0000NBK-00 with the last firmware 1.01.77 but when i try to play a mp4 file there`s no sound. The file atributes are:
General
Complete name : C:\Users\Administrador\Desktop\dr\movie.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 105 MiB
Duration : 43mn 55s
Overall bit rate : 335 Kbps
Encoded date : UTC 2010-03-26 17:10:48
Tagged date : UTC 2010-03-26 17:10:48
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 43mn 55s
Bit rate mode : Variable
Bit rate : 268 Kbps
Maximum bit rate : 688 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.039
Stream size : 84.2 MiB (80%)
Writing library : x264 core 56 svn-676
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=268 / ratetol=1.0 / rceq=‘blurCplx^(1-qComp)’ / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Tagged date : UTC 2010-03-26 17:11:32
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Codec ID : 40
Duration : 43mn 55s
Bit rate : 64.0 Kbps
Maximum bit rate : 70.2 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 20.1 MiB (19%)
Encoded date : UTC 2010-03-26 17:11:30
Thanks for help…
