Wd green sdd wrong trim!,? Pls help
Hi . I have wd green ssd 120g2g0a and i have dashboard v 1.4.4.5 .so first question: this ssd support trim? Second : in to dashboard I see the trim option and click on it and said trim progress at the same time i open windows default defragment tool and i see also windows defragment is working with dashboard and defrag my drive . So that’s is ok? And after trim i go to dashboard smart detail and and see my total gigabyte written . Before trim was 810gig and after trim 815 . So am completely confused . Help.
Help. Anyyy body hear me??
Don’t be impatient. It often takes more than a few hours for people to respond.
You might read this article; it explains a lot.
https://www.hanselman.com/blog/TheRealAndCompleteStoryDoesWindowsDefragmentYourSSD.aspx
