I’m having some troubles with my hard drive, I can’t get it to work with my Mac. I’ve looked at the guides but I can’t follow the steps because it says "You can’t resize the partitions on this disk because it uses the Master Boot Record partition scheme.
If your hard drive is formatted to work on windows computers, you will only have read only access. Check the link below for the steps to format it again for Mac, this will of course will delete any files that you have inside so be sure to backup any important files that you have inside. You can also try downloading Paragon NTFS to have write access to the hard drive without having to change the format.
