I have got updates from the software “WD drive utility”, but the problem is the same
The Device is WD Passport WDBBEP0010BBK-01
Running on Win 7, 64 bit
The problem is there, without the passport connected to the PC.
Then the 2 WD services are running on the PC, the LAN to Router has large delays (timeout in programs, and bad for online games) ping times up to 2000 ms
Turn off the services and all is fine.
I have to turn the services off every time I start the PC, but the service are active again, as soon as I start a WD program.
I think it is the “WD Driver Manager” there has some problem getting in contact to a service on the internet, but I dont understand the large ping times. There is no problems with ping to other PC on the LAN.
It is the same problem with 2 different brands of routers, and other cables, same problem.
Connect a PC without the WD software, no problems.
