WD Drive is full
My drive is full because I was backing up 2 drives. Now how do I wipe it clean and set it to back up only my C drive?
You could just format the drive, this will delete all data stored on it.
If you are using WD Smartware backup software then you just have to delete the backup folder. It is called “WDSmartware.swstor” and it is located in the root of the drive.
Thank you so much!
