hello,
i have a new 4TB WD blue and issues with it going into sleep mode (spindown).
it is configured as drive E: and a pure DATA disk.
i replaced a 3TB WD green that had no issues going into sleep mode … it worked just fine.
i know how to setup energy saving features in windows 10 and i made sure that the system is not accessing the 4TB WD blue, preventing it from going into sleep mode.
there is no cache or swapfile on E: there is no tool accessing the drive.
again… when i replace the 4TB BLUE with the 3TB GREEN all works as expected.
the drive is a DATA drive as i wrote so it could be idle most of the time.
and i hear the annoying noise the drives motor makes.
it´s just the normal noise the motor makes but i have an absolute silent system otherwise so it is annoying.
the GREEN is a WDC WD30EZRZ-00WN9B0
the BLUE is a WDC WD40EZRZ-00WN9B0
just as info i tried a 4TB drive from WD´s main competitor and of course it worked just fine.
im pretty much clueless why this drive won´t go to sleep (spindown).
Festplattenübersicht
Festplatte Nummer,5
Schnittstelle,“S-ATA Gen3, 6 Gbps”
Laufwerks-Controller,“Standardmäßiger SATA AHCI- Controller (AHCI) [VEN: 8086, DEV: 1C02] Version: 10.0.14393.206, 6-21-2006”
Laufwerksposition,“Bus Number 5, Target Id 0, LUN 0”
Festplatte Modell-ID,WDC WD40EZRZ-00WN9B0
Firmware,80.00A80
Seriennummer, WD-WCC4E3E-----
Gesamtgröße,3815445 MB
Power-Status,Aktiv
Logische Laufwerke
Logisches Laufwerk,E: [Bunker]
ATA-Informationen
Anzahl Zylinder,7752021
Anzahl Köpfe,16
Anzahl Sektoren,63
ATA-Revision,ATA8-ACS
Transport-Version,SATA Rev 2.6
Sektoren gesamt,976754646
Bytes pro Sektor,4096 [Advanced Format]
Mehrfach-Sektoren,16
Fehlerkorrektur-Bytes,0
Unformatierte Kapazität,3815448 MB
Maximaler PIO-Modus,4
“Maximaler ““Multiword DMA””-Modus”,2
Highest Possible Transfer Rate,S-ATA Gen-3 Signalgebungsgeschwindigkeit (6 Gps)
Negotiated Transfer Rate,S-ATA II Signalgebungsgeschwindigkeit (3 Gps)
“Minimale ““Multiword DMA””-Transferzeit”,120 ns
“Empfohlene ““Multiword DMA””-Transferzeit”,120 ns
Minimale PIO-Transferzeit ohne IORDY,120 ns
Minimale PIO-Transferzeit mit IORDY,120 ns
ATA Control-Byte,Gültig
ATA Prüfsummenwert,Gültig
Akustikmanagement-Konfiguration
Akustikmanagement,Nicht unterstützt
Akustikmanagement,Deaktiviert
Aktueller Geräuschpegel,Vorgabe (00h)
Empfohlener Geräuschpegel,Vorgabe (00h)
ATA-Features
“”“Read Ahead”“-Puffer”,“Unterstützt, Aktiviert”
DMA,Unterstützt
Ultra DMA,Unterstützt
S.M.A.R.T.,Unterstützt
Power-Management,Unterstützt
Schreib-Cache,Unterstützt
Host-geschützter Bereich,Unterstützt
Advanced Power Management,Nicht unterstützt
Extended Power Management,Nicht unterstützt
In Standby einschalten,Unterstützt
48-Bit LBA-Adressierung,Unterstützt
Gerätekonfiguration Overlay,Unterstützt
IORDY-Unterstützung,Unterstützt
Lesen/Schreiben DMA-Warteschlange,Nicht unterstützt
NOP-Befehl,Unterstützt
Trusted Computing (Hersteller kontrolliert Hard-/Software),Nicht unterstützt
64-bit World Wide ID,0150E24E4F6344C9
Streaming,Nicht unterstützt
Media Card Pass Through,Nicht unterstützt
Mehrzweck-Logging,Unterstützt
Fehler-Logging,Unterstützt
CFA Feature-Satz,Nicht unterstützt
CFast-Gerät,Nicht unterstützt
Lange Physikalische Sektoren (8),Unterstützt
Lange Logische Sektoren,Nicht unterstützt
Schreib-Lese-Verifizierung,Nicht unterstützt
NV Cache Feature,Nicht unterstützt
NV Cache Power-Modus,Nicht unterstützt
NV Cache-Größe,Nicht unterstützt
Freifall-Kontrolle,Nicht unterstützt
Freifall-Kontrolle Empfindlichkeit,Nicht unterstützt
Nennumdrehungsgeschwindigkeit,5400 RPM
“”“Serial ATA”“-Features”
S-ATA-Erfüllung,Ja
S-ATA I Signalgebungsgeschwindigkeit (1.5 Gps),Unterstützt
S-ATA II Signalgebungsgeschwindigkeit (3 Gps),Unterstützt
S-ATA Gen-3 Signalgebungsgeschwindigkeit (6 Gps),Unterstützt
“Quittiere ““Power Management””-Abfragen von Host”,Unterstützt
PHY-Ereigniszähler,Unterstützt
Nicht-Null Puffer-Offsets in DMA Setup FIS,Nicht unterstützt
DMA-Setup Auto-Aktivier-Optimierung,“Unterstützt, Deaktiviert”
Geräte-initialisierendes Interface Power Management,“Unterstützt, Deaktiviert”
Ablauf-bedingte Datenübergabe,Nicht unterstützt
Asynchrone Benachrichtigung,Nicht unterstützt
Erhaltung der Software-Einstellungen,“Unterstützt, Aktiviert”
Native Command Queuing (NCQ),Unterstützt
Warteschlangenlänge,32
