How does one change audio tracks when playing videos with multiple soundtracks?
It’s a snap on Apple devices, but I can’t find anything on the Android players.
I have to be missing something obvious, because it can’t be a missing feature…
Try installing a video player like MXplayer and select it to play the file from the WD2go app.
…but that won’t “stream.” I have to download the whole file first and then open it somewhere else.
Ichigo, just a quick followup to let you know that your solution worked perfectly. I didn’t know that the WD 2go app would internally redirect streams to other apps for playback.
I installed MX Player and it works beautifully.
Thanks for the help!
Awesome!!
