WD 2 TB Purple hard drive not detected
Hi
WD 2 TB purple Hard drive is not detected .12 TVS diode was damage and i removed still have contiunity in diode point .
capacitor is marked in green also damaged any one knows the value can you share
Anyone Share your ideas…
first off that disk is old but I am not sure of the part numbers for the various TVS diodes
usually they are damaged when a crappy PSU is in use
Hi
even if we remove TVS diode still continuity . anyone have idea
PCB No : 2060 771945 002 Rev A
I tried that on a dead disk, did not work as other components were damaged
