[WD 10B8 2TB] HD recognized but does not work
I have a WD 2TB (Elements 10B8) and it does not show up anymore in “Comptuer” when I plug it. It is recognized because the computer installs drivers at first plug in and he is in the list of devices :
I have installed the WD software (Data Lifeguard) to test it but there is no error.
[[DELETED - PRIVACY - SERIAL NUMBER SHOWN]]
Do you have any idea to make it work again ?
Thank you!
Edit: Reuploaded image without serial…
Hi, you can try assigning a drive letter and if the computer is able to recognize it.
Somebody used my disk to backup his Mac (not readable on windows)… I just formated it to DOS (with the mac) and to NTFS just after with my PC. Now it works properly.
Thank’s
