Waranty on replacement product
I received a replacement product ,passport external hard drive is there an extended waranty on the replacement product? And if there is how long is it for.
Hello anthony_o_neill,
The warranty left on the defective drive will be transferred automatically to the new unit.
The waranty was just up on faulty unit .so will replacement unit have any waranty on it?
Please note that this is a user to user community, not a direct support venue. Please create a case with support to get a direct answer from support.
http://support.wdc.com/support/case.aspx?lang=en
