New WD My net 750, and the wan port just randomly dies for a second or two and automatically reconnects. Tried 3 different cables, same thing. Logs indicated WAN down, then immediately WAN back up.
Have read to switch to AP mode, which I have, and will monitor it, and see if the wan continues to just randomly die (and if it does, back to the store it goes)
Also, in AP mode, how do I see connected wireless devices? In router mode you could (well, the hostname and IP address), but this feature is gone in AP mode?
And seriously, no RSSI, no link strength, no sync rate stats at all? Even my router from 2007 can do that…
Not impressed with the product so far… (although bein said, the wireless speed is half descent so far, but if wan just keeps dieing, its basically useless, cant have a voip call just die randomly for no reason)
edit, another “goodie” ive found, in Connection status, its always reporting uptime of
Connection Up Time 0 Day 0 Hour 0 Min 18 Sec
always 18 seconds. lol. this product is awesome.
And yes Im on the latest firmware.
