Volume Failure - Need Help
I got the following errors on my MyCloudEX2Ultra.
I just discovered this as I have been away for a little while.
Volume Failure
The data volume 2 on the drive is not accessible. Contact WD Support.
Monday, October 18, 2021 9:26:58 AM
Code:4
|File System Check Failed|
|File system check has detected errors on your configuration. Backup your data and recreate your drive configuration to resolve these errors. If problem remains, contact WD Support.|
|Monday, October 18, 2021 9:28:31 AM|Code:36|
I am hesitant to upgrade to the new OS5 until these issues are resolved and I backup my files.
Right now, I can’t backup since I have a volume failure.
Please Help.
Hi @DARKSHARK,
