Hi… i have my WD TV Live connected to my yamaha reciever with optical SPDIF cable, and when i play movies, the people voices are too low and the effects too loud. Before, i had computer connected in the same way,but everything was ok… I have two Mission speaker connected to my reciever… any help ?? thx
Have you tried the “Dynamic Range Control Setting” to see if this alleviates the problem ?
Setup > Audio/Video Output > Dynamic Range Control Setting > [Press “OK” to Select]
Try “Max” as a 1st Test.
Yesss… now is better… thank you…
No, Probs
Click the “Kudos” Star if this was of any help to you.
