Wireless bandwidth is not large enough to transmit vob files?..? I would think lots of people would have this issue. WD codec issue? WD firmware issue?
MP4 files transmit over my network just fine. And I’ve just discovered that I can successfully transmit vob files over my wireless using playon but then have issues playing vob files sequentially.
How much bandwidth is necessary? WDTV LIve is wireless and supports vob playback. I don’t see doc saying vob is only supported locally…
I’m not saying it’s a limitation of the WDTV. I am saying that your wireless connection appears to be unable to maintain the 15mbps (approx) to stream DVD VOBs.
PlayOn is a transcoding DLNA server, so saying it works via PlayOn doesn’t mean much.
So now this WD box has completely stopped working.
I unplugged it to reset it and afterwards it will not connect to windows shares or my media server. So I did a hard reset and now it’s decided to not output ntsc. All I see is WD scrolling on my screen.
I’m really regretting getting this media box. Sure doesn’t work as advertised.
Now I need to figure why I can’t play dvd files. Vob files play fine from local storage. But if I try to play the same files from my server share or thru PlayOn MyMedia I can’t play them.
I am trying to turn off wireless to see if bandwidth is an issue. Once wireless has been enabled what do I do to use a wired connection?
So I reset the box again with an ethernet cable plugged into my router and the box. Then I run thru the usual setup like choosing a language and it detects the internet.
But it will not detect the windows shares that are detected using wireless. I want to determine if using a wired connection to stream vob files will work since there are playback issues using wireless
Why are windows shares detected using wireless but not wires?.
It was postulated that the reason I could stream vob videos wired but not wireless was due to a throughput issue with my wireless network. I verified that I have about 90-120 mbps wireless bandwidth and a gigabit ethernet adapter on my computer.
It seems to me that my bandwidth is large enough to allow decent throughput that should allow for vob streaming…
