Hi all,
I’ve recently purchased a Vizio VSB200 sound bar. I’ve connected my WD HD unit to my sound bar via the optical cable, went into setting and switch my sound output to Digital output.
My Vizio sound bar then gave me an error code where it says no PCM audio output detected. So I would assume that my WD HD unit only output AC3 for digital sound?
Did I miss something here because the WD HD manual says that the unit is compatible with PCM digital sound.
What should I do?
Any help or suggestion would greatly appreciate!
Thank you in advance!
