Disore
August 3, 2012, 5:13am
1
I have very slow speed from my work computer to my BookLiveDuo which is at home.
Both on work and home internet speed is high (download and upload) - no problem.
At home I have ADSL modem which provides me internet, so upload speed is not too high, but normal.
From my work comp I have access to my home BookLiveDuo so I can upload some files.
It uploads well but the speed is too slow - about 10-20 kbytes/sec and even slower.
There are no firewalls on the way of inforamtion transfer (I suppose).
Where is the problem? Help
Vadir
August 3, 2012, 9:16pm
2
What is the upload speed you have at home? How are you accessing the drive remotely? Using WD2Go or a different method?
Disore
August 6, 2012, 7:27am
3
Sorry for my bad, I have ETHERNET connection at home, not adsl.
Upload speed is about 100 mbits/s, realy about 60-80 mbits/s (equals 7.5-8 mbytes/s).
I connect to my drive through WD2Go site (it creates network drive in my computer)
I connect from my work computer, it also has fast ethernet connection. i can’t see the reason
That’s the reason right there. Fast Ethernet is 100 megabits per second max.
Disore
August 8, 2012, 8:53am
5
Yes! But for me 100 mbits it is fast. Mu connection speed with MyBookLiveDuo is about 0.16 mbits. See? Almost in 100 times less than must be. (0.16 mbits = 20 kbytes)
Any fix for this? I’m having the same issue. At home, transfering speed seem to be reasonable. I have a Time Capsule which is act liek my router and I connect the MBLD to it. The modem is comcast. If I mouted the drive at work it would be so slow.
