Yesterday I decided to upgrade my firmware for some reason, not sure why since everything was working fine.
After upgrading from the original firmware that came with the device to the 1.02.10 I noticed that:
1) I have to use a password to connect to my DataVolume/Download folder (annoying) —Solved solution below.
Twonky will only list files in DataVolume/Public/Shared Videos.
the admin site takes minutes load a page each and every time, making diagnostics painfully long and frustrating.
I did not experience the disconnect issues that everyone else seemed to have. I have since downgraded back to 1.02.06, but the problems persist.
To attempt resolve the Twonky problem I have made sure that the folders are shared with all content types and verified that rescan is set to -1. I have also tried to restart the server and rebuild the database but nothing seems to make it work.
I was able to resolve the password protected folder. Creating a new user that was the same user name i log in to windows with apparently created the problem, deleting the user and creating one with a different user name solved this problem.
Any help would be greatly appreciated.
Thanks!
Edit- My device is the MBWE 2tb white light.
