I just bought a DL2100. On the WD Support Website I found a list of compatible drives for the DL-Series, no mention of WD REs. Any chance I can use my WD RE Drives ?<
Has anyone tried?
Many thanks in advance !
Chris
Has anyone tried?
Chris
I haven’t try that. However, to make sure that you get an optimal working unit, I’ll recommend you to use the drives on the compatible list.
They’d probably run hot. Not sure how good that would be.
Here is the compatibility list.
https://support.wdc.com/product.aspx?ID=2703&lang=en#WD_compatibility
