Hello everyone.
I am using a 2Tb MyBook World edition (blue rings) as one single disc. Now I want to use the two discs inside the NAS as two seperate discs, without one automatically backing-up on the second. Is that even possible?
Using the “shared storage manager” I have only found , under “drive management”, the choice between “large single volume (linear)” which I am currently using, and “secure volume (raid 1)”, which I don’t want to use.
So either I am unable to find the solution and then you have to help me or it is not an available option. In that case, is there any “other” solution?
Thanks in advance for any help.
