Using IOS is it possible copy to sd card? My Passport Wireless Pro
What I wish to do is to copy FROM the WDMPP TO the SD card for light weight backup. This is a check of the ability to do this, since it has been answered before, but SW and FW changes…
I point out that there is no computer available. Only the SD card, a IOS device and the WD device.
You can backup files manually from your My Passport Wireless to a USB drive. For this, open the mobile App and select the files you want to back up, at the top right-corner select the three dots and then “Copy”.
A new Window will open where you’ll be able to choose the backup destination, in this case the USB drive and/or its sub-folders, then select the Paste icon.
