Using headphones with the WDTV Live Hub?
Just wondering if this is possible and if I need an amplifier/adapter to enable it. Directions to products would be beneficial as well. Thanks…
I use my xbox wireless earphones with mine - turlebeach x41’s. I play on xbox live so they are worth it for me.
connect via optical on the live hub to the x41’s base station. They sound good but battery life on headphones aren’t great.
Other options are connect tv red/white audio to live hub red/white - composite? anything played through the tv goes through the headphones.
got it figured out now. i have the tb px21’s and just used the composit cable. works perfect. thanks for the reply
