Hi
Is it possible to use both ports at the same time?
Hi
Question…why would you want to use 2 ports at the same time?
You can’t use 2 ports on the same or different computer… period
You can only conect to first plugged in interface USB or 1394.
It will ignore the 2nd conencted interface.
