I have 6 TB MY BOOK WDC External drive. S/N WD60000H2Q-00. Since it has the hardware requirements (eSATA connector,) I would like to connect it to my TiVo Bolt to expand recording memory. TiVo claims that the only drives they support are listed below.
Does Western Digital have any firmware that will allow this 6TB drive to be used as a TiVo DVR expander? It seems like the only difference between this HD and other eSATA drives is the size of its storage capacity. If I simply erase it and connect it to the powered off TiVo then restart everything, is there a danger in damaging the TiVo if it does not work?
WDC WD10000F032
WDC WD5000F032
WDC WD5000AVJS-63TRA0 - Firmware: 12.01C01 - Size: 500 GB
WDC WD5000AVJS-63ZWB0 - Firmware: 01.01B01 - Size: 500 GB
WDC WD5000AVJS-63H0B1 - Firmware: 05.04C05 - Size: 500 GB
WDC WD10EVVS-63E1B1 - Firmware: 01.01A01 - Size: 1000 GB
WDC WDG1S5000VN - Size: 500 GB (My DVR Expander eSATA Edition 500GB)
WDC WDG1S10000VN - Size: 1000 GB (My DVR Expander eSATA Edition 1TB)
WDC WDBABT0010HBK - Size: 1000 GB (My Book AV DVR Expander 1TB)
Thank you in advance!
