will this work with the box ?
are pretty much all wireless adapters compatible with the wdtv live plus ?
thanks
thanks
It’s gotta be good when they don’t even give a manufacturer name on the box.
No… quite the opposite. You have to be very careful with both brand AND revision… even newer versions of ones that used to work, may no longer work, depending on the chipset used in it.
