At first i want to apologize when my english is not as good as yours.
I am new here and i heard about this Forum on the German HelpLine from WD.
At first my Problem.
I have a WD TV device (Firmware 1.03) and I connected an WD 1TB my Book Essentials HD. This external HDD has no chance to switch off with an I/O switch. So it has to switch it off by sending no Power trough the USB cord. with My PC it work great butwhen I connected it to the WD TV device and switch this one off the HDD get power form the device anyway. Is this a Problem someone knows…can it be fixed. dows anyone knows if WD plans to fix it by new Firmware
It just su** to switch the device off an i have to move to my TV an fingering in the very farest corner to pull the Powerline from it.
Thank you for your attention
With kind regards DNLupus
Sorry but i havent found something with this headline
For the Live it normally does power off a USB drive attached to it… but not always. I had one drive that wouldn’t power off with it and there was nothing I could do about it. However, if you buy a SmartStrip power strip this will definitely turn the drive off (you plug the drive’s power into the SmartStip and when you turn off the power on the Live anything that’s also plugged into that strip turns off):
