USB-C to USB-C cable recommendations for WD My Passport Ultra
The stock cable that came with my My Passport Ultra is starting to fray. Can I use any standard USB-C phone charging cable, or do I need a specific high-speed data cable to maintain transfer speeds?
@cythiawhite
Have you looked at the WD web site and the information provided for your device?
1TB Silver My Passport Ultra | WD
USB c Cables
I have found modern USB-C cables work at 40 gigabit with few problems. Avoid dollar store cables. I have some Essager cables from China which work great.
You don’t necessarily have to buy an official WD cable, but avoid using ones that are too cheap. It is recommended to choose a high-quality USB-C cable that supports the USB standard required by the hard drive.
Thanks, I’ll check it.
Got it. Dollar store cables are a trap. Thanks for the recommendation!
Thanks, I won’t skimp on the cable.
