USB 2.0 cable Part Number 4064-705050-002- AC
Can I buy one of these from WD? I have a 2TB p/nWDBAAU00HBK drive that seems to have failed, but I have suspected the cable for some time now.  I have a 2 TB My Book also, but it uses a different cable (USB 3.0). Thanx.
Depending on your location, the support department might be able to help you buying this cable as this cable is no longer available through the WD Online Store
WD Support contact info:
http://support.wdc.com/country/index.asp?lang=en%22
