Hello All,
Hopefully someone can help with what I thought was a simple thing to fix. UPnP is enabled on my router but the mybooklive must be using a different protocol or something as its not detected (DGND3300 Netgear) The UPnP has options of Advertisement Period and Advertisement time to Live, current set to default of 30 and 4 respectively. Having the normal automatic setting failing, I have tried manually to get a direct connection. Using all settings in the router eg. Port Forwarding, opening firewall ports, and port triggering I cannot get the NAS to direct connect with either custom ports or 80 and 443.
Anyone else with this issue and anyone with any solutions?
