Uploading images to a MyPassport Wireless Pro
Is it possible to upload digital images from a CompactFlash card using a USB3 card reader to the My Passport Wireless Pro?
Hi Petergwy,
You can upload digital images with compatible image file formats such as jpeg, jpg, jpe, jfif, jif, jfi in My Passport Wireless Pro.
Moreover, you may refer below KBA to check for compatible flash card and card reader details:
https://support.wdc.com/knowledgebase/answer.aspx?ID=11737#wirelesspro
