Good news, WD EX2 has now put out an update for nzbget from v11 to v13, bad news things dont work.
So after upgrade the nzbget download directory has changed from Public\Nzbget\dst to just Nzbget\dst
Problem 1 , is even after I used interface to share this folder I cannot access it as a mapped drive from windows, says I dont have permission to access WDMYCLOUDEX2\nzbget
How do I fix this? I assume I will have to ssh into it and share it that way
Problem 2 is that unrar no longer works, when Nzbget tries to unar the download files I get the message
Unrar: Could not start /usr/bin/unrar: No such file or directory
Since NZBGET created the new folder the access is restricted, proper folder permission not granted , not sure why NZBGET did this but anyway…
So, I deleted the new NZBGET folder and changed the pathway for file saves back to
MainDir : /shares/Public/nzbget
now everything is back where they started and no more issues with access
Problem 2 solution :
NZBGET changes the location of UnrarCMD to /usr/bin/unrar, this is not where Unrar is located, to correct this the directory should be : /usr/ local /bin/unrar
same for the SevenZipCmd , directory location of file should read /usr/ local /bin/7za
For number 2, this was indeed an error on my side. I have fixed this for the next release that should be avialable for update soon (NZBGet v14.1).
For number 1. In order to meet WD’s user/security requirements I was asked to have nzbget create its own private share. You should be able to access WDMYCLOUDEX2\nzbget as user admin.
Just a heads-up. At next update if you have file and settings pointing to Public\Nzbget these will be moved and edited back to Nzbget… so you may want to chnage it all to something else to prevent it all being moved on update. i.e change this ti Public\myNzbget or similar.
HomerJ I have the same problem (number 1). I changed the dst folder to shares/Public as I could see downloads happening successfully to shares/nzbget/dst but I could not access them there. However, when I changed to Shares/Public it cannot write to the folder as it throws up a low diskspace error message. Please could you share your exact file path that worked. Sorry I am a noob
