Upgrade from 1.01.17 to 1.01.24 and display stuck @480p
Hi guys,
Recently I have upgraded my wd box from 1.01.17 to 1.01.24. All went fine but after reboot my screen resolution stucked at 480p. I did an upgrade using network (not an usb stick) having external disk attached to wd which is connected to tv via hdmi and optic to amp. Anyone else is having similar issues after upgrade?
Have you reset the unit via the side hole. The unit may be stuck after the upgrade.
I completely forgot about this little reset button. Thanks richUK , WD works fine now.
To help others it might be worthwhile if you pushed the problem solved button.
Good idea :wink:
