Updated to 3.00.28 and now what is happening the hub will compile the library and when I shut down the unit, it appears the unit is going into a COMPLETE SHUT down as the hub disappears from the network, and when I turn back on the hub, the unit will go through the full loading process of with the two WD screens, and then it will start to complie the library again!..
I did the following
- Went back to 2.08.13 and the same thing
- Delete the library file, and rebuilt same thing
- Reset the unit to factory setting and the same thing
HELP WD!!!
