Unstable and very slow connection to WD MyCloud
I have a problem with My Cloud 2TB that has a very slow connection and unstable, I can’t open the webpage for the Cloud it takes minutes to open and to put a setting, also when I want to view files it takes more than 5 minutes to view them and after few minutes it turns offline!!!,
The connection speed between me and My Cloud 1 Gb/s,
I used FTP to transfer files it transfers pretty fast but after few files, it turns offline!!
I’ve done a hard reset (40s reset) but the problem is still
@mongid Have you looked at The Learning Center and the Resources available for the My Cloud Home?
My Cloud or My Cloud Home ?
If My Cloud … then you’re in the Wrong Forum
