Universal firmware
hello I previously upgraded with an external hard drive firmware, but I am not power cycle the beep began to arrive from disk to disk, I guess I do not know exactly changed the firmware version of the 1.003, but still the same problem, I want to upgrade to a higher one to wonder why I’m afraid I can not do video narration Are you? What is the power cycle if I do not know also if you put a picture happy thank you in advance;)  I TURKISH english bad :smiley: google translate :))
If the drive is working without problems don’t bother with the update. Power cycle means disconnect the drive USB  cable and if it’s a powered deive unplug power adapter.
Joe
