Unit unresponsive after playing for a while
I am streaming AVI files using Twonky from a Win7 computer. There are no compatibility issues with the files: they play on three different computers, on the Logitech Revue, and on Netgear Digital Entertainer. They also play on the Live Hub but there’s a catch: after playing any of these files for about 15-20 minutes, the units stops responding to Stop/FF/Pause. I cannot stop the movie from playing but I can use the back button to go to the menu. If I wait out the movie to end, same thing happens (the player won’t go back to the Video menu by itself). I can launch other applications but if I try playing another file (or the same one), all I get is the spinning arrow. The unit would not play anything until a restart. It does the same thing with files I copied to the internal drive. I also formatted the drive, reset the unit to factory settings, and no go. Same problem. It happens every time. Support has been MIA and I am at the point of returning the unit. Is there anything else I can do before that?
I did, by e-mail. No response so far.
Looks like this is a bit of a common issue now. I also contact WD support and they sent me a new LiveHUB but I still have the same problem. Seems to occur when accessing both locally and via network share.
http://community.wdc.com/t5/General-Discussions/Error-message/td-p/142728
http://community.wdc.com/t5/General-Discussions/Issues-with-WD-TV-Live-Hub-wont-stop-playing/td-p/141074
I’m going to try putting the new public beta firmware on tonight and see if that solves the issue.
I can now reliably replicate the problem and I cros-posted this to:
http://community.wdc.com/t5/General-Discussions/Issues-with-WD-TV-Live-Hub-wont-stop-playing/m-p/147742/highlight/false#M7272
Support has been particularly unhelpful: they ran me through the usual stuff (reboot/check internal HDD/check USB/firmware) when it is crystal clear to me that it is a software issue. Basically:
  1. After rebooting, the unit plays every file I’ve tried
  2. If I stop/pause 10-15 min after starting playback, the unit responds normally and I can resume play, choose another file, or whatever
  3. If I let it play for over 20 minutes, then it becomes unresponsive to the pause/stop buttons. However, it does respond to the ‘Back’ button, which takes me to my file listing. The kicker is: I can still hear the audio from the movie being played, which tells me the player has not quit and is working in the background. I can navigate my menus just fine but if I try to play another file, all I get is the spinning arrow. This happens even if I wait for the player to finish (again, going by the audio).
  4. At this point, only rebooting helps.
  5. This happens with files from the internal drive, from USB, from a network share, and streamed with Twonky from a Windows computer.
It is clear that the software player is going into a loop and would not quit. I cannot imagine this to be related to the hardware. Since the unit really plays everything I have thrown at him, I really would like to keep it. But I can’t do it if this means rebooting after every playback.
I have the exact same issue and set of symptoms. I even had a new WDTVLIVEHUB sent to me under RMA warranty and still the same issue, so its definitly not hardware related and is a software issue.
Anyone at WD have an help on this issue?
ok, so i installed the public beta firmware (2.04.13) and unfortunately the issue still exists. After 20mins the pause/ff/rw/stop functions don’t work and at the end of the file the screen goes black. If you use the back button and select a 2nd file to play the orange circular arrow continously appears and unit then requires a hard restart.
