Hi, I’m using the WD TV Live with an Airlink Golden 150 Wireless Adapter. I understand that iniitially there was a problem with the Version of the driver on the wireless adapter - i.e. unless it was Rev 0200 it would not work. But I read some posts recently which said that the problem has been solved if you upgrade the WD firmware to the latest Beta release. So I did that.
But now when I go to Network Settings > Network Setup > Wireless > Automatic, it shows me an old SSID that I used to have previously. It does not detect my current home wi-fi network’s SSID. Even when I try to do it Manually, it does not work.
Can anyone please help me?
