wct275
1
After 6 months plus and previously without issue, my home WD Cloud storage system is unable to connect with “system offline” message.
Without changing anything, at home, connection to the Cloud is WITHOUT ISSUE.
Intermetently when I disable WiFi for a short time the cloud is accessible then less than 1 hour I have “system offline”
Any ideas?
Are you in Europe or Asia? If so it looks like there are having some server issues.
http://status.mycloud.com/os4
wct275
3
Hi. Im in Malaysia. Many thanks for sending the link. Saved me from going out to buy another system
I’m in Thailand and I still have a problem. Have the problem be solved yet??
