Twonky not starting after Firmware upgrade
Just upgraded to 2.2.9… and have noticed that Twonky isnt auto starting…
I can start it manually with the following command  /twonky/twonkymediaserver    and it works ok…
Having a look in /etc/init.d  there is a script called S97twonkyserver     I only understand basic unix… bit it looks like its starting a file called  twonkymedia in the /twonky directory…
If I reboot the box… when I initally cd into the twonky directory there are very few files…  leave it a few minutes and they all appear (odd)
Anyone else having probs with twonky since the upgrade ?
Sorry I am a linux noob…   so any help would be much apreciated
PS: I have logged a support call
Best Regards
Craig
Seems to be working fine here…
