I have got my mac networked to the wd media player. but when I try to play movies from my mac, there is no sound and the frame seems too be slow or not as smooth as it should be…
my second problem is that when I use netflix, it seems that the sound is not in sync with the video. its watchable, but it just seems to be a bit off.
I have the new firmware update 1.04.22. I was wondering if I should downgrade my firmware and if so what firmware should I use?
any advice or info would help
