It appears that my 8TB sentinel is running into issues working with OSX 10.9 clients via time machine (or from what I can tell, it’s really the other way arround.) I’ve done some reading and it seems that apple decided to move to an SMB based approach instead of AFP for the new iteration of the time machine client. The end result I get is that when I attempt to connect using a 10.9 host, I get a notification indicating that the server either does not exist or is unavailable. Interestingly, the NAS still shows up in the list of drives to pick from when setting up time machine.
Current environment:
1x OSX 10.9 client (time machine non-functional
2x OSX 10.7 clients (Time machine working as expected
1x OSX 10.8 client (time machine working as expected)
2x Windows 8.1 pro (x64) clients (automated backups working as expected
1x Windows 7 ultimate (x64) client (automated backups working as expected)
I’m investigating the issue from both approaches, the NAS side and the client side.
Has anyone had any luck getting Time Machine on mavericks (10.9) clients working with the sentinel?
This is actually from the newer version, but my guess/belief is that the apple products are the same, but I am not an Apple persona AT ALL
Domain Join and Backup using http:\ {ipaddress of server}\Connect
Windows 8, all 32-bit and 64-bit platforms
Windows 7, all 32-bit and 64-bit platforms
Mac OS X v10.5 Leopard with Time Machine
Mac OS X v10.6 Snow Leopard with Time Machine
Mac OS X v10.7 Lion with Time Machine
Mac OS X v10.8 Mountain Lion with Time Machine
Copied from here. The box you have will also backup XP and Vista. The new one will not. I swear I heard someone who knows Apple say it will never work cause of the change you mentioned.
1.7.3.13 update popped up as available today. Applied the update and everything suddenly works like a dream. I guess I just needed to be a little more patient!
On a side note, after spending a half hour updating the firmware on my home NAS, I get to go into work tonight and run a microcode update on a large SAN storage array… when firmware rains it pours…
