Hi guys!
I have set up My cloud but I have problem with Time Machine, after the first backup was finished I received the following message (look below) when Time Machine attempted to make next one.
What do I do wrong? How to fix it?
System: MacBook Pro 15
Mavericks
One of the reasons that happened to me too is the NAS seems to need reconnecting everytime I open my laptop. In other words it seems to disconnect on sleep so cannot backup
No it’s on, not in the sleep mode and there is connection
I’m having the exact same problem. Any luck making this work?
I’ve got the same problem. Only solution I’ve yet to find it the “old pull da’ plug” to restart option. Which is not what I would call optimal.
I’ve had mine backing up and running for a week after much fooling around.
Static IP
media server off
mycloud sharing off
Sleep off
and my computer never sleeps.
First back up done plugged in, then Wifi after.
When I reconnect to my network I re-mount the MyCloud drives manually with connect to server and sign in.
Mycloud 2T
Mavericks MBP running Time Machine
WRT-54g running Tomato
Airport Extreme GEN1 bridged
