my my passport 2tb have got a check mark on read only thadle and i cant do any thing wit this can anyone help me pleas?i used bitlocker and when i removed it,this problem happend.i’ve used chckdsk and attrib commands on cmd but they did not worked.it happend to all my computer then so i formatted it,i’ve read that its anew viruse so try to use freez mode when you are on internet.
It is recommended to format the drive. You can refer the link mentioned below to follow the steps properly to reformat the drive.
Make sure, you scan your drive with Anti-Virus before transferring any data into the drive.
Hi vladimirlyobov,
Did you do this reformatting, and did it fix your problem. I have the same problem here.
