Hello:
I have 2 My Book World Edition II NAS drives. They both are configured to use a static IP address and both are on the same workgroup.
One of them is supposed to be replaced with a newer one that I just installed yesterday.
What I am trying to do is to transfer all the information from NAS1 to NAS2.
Both are connected to a router.
I created a batch file that was basically several xcopy commands to copy all the information from NAS1 to NAS2.
As this process was going to take like 8 hours I ran the batch file yesterday at 4:00PM when everyone was logged off the NAS drives.
To my surprise this morning I found out that only a portion of the files were copied from the NAS1 to the NAS2.
After reading the system logs of the NAS1 drive I found a lot of errors.For example:
getpeername failed. Error was Transport endpoint is not connected
Error writing 4 bytes to client. -1. (Connection reset by peer)
write_data: write failure in writing to client 192.168.10.105. Error Connection reset by peer
write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
The logs of the NAS2 drive do not have any errors.
Anyone knows what those error mean?
A failing hard drive from the NAS1? Or maybe a network configuration problem?
By the way I have never updated the firmware on either NAS drive.
Thanks and help is greatly appreciated.
